Power steering pump. 91 pump in an 89?
    Is the power steering pump from a 91 Crown Vic the same as the pump on an 89, other then the flow control valve.
    Can I just swap the flow control valve from the 89 pump to the 91 pump?
    My pump has a very slow leak and the one on the 91 parts car with 60,000 miles looks good but has a different fitting. I already removed the pump from the parts car but didn't buy it yet.
    I was going to put new seals in my pump and I'm thinking it might come in handy to have an extra pump before I take my pump apart.
    Is it worth buying for $19.00?
    same pump
      91 should be an identical pump, lines, fittings, etc.
