difference between 8.5 and 8.8 axles?
    Hi everyone, I'm sure this is somewhere in the archives, but the search function has been so slow for me that I figured this might be faster.
    What is the difference between the ford 8.5 and 8.8 axles? I have an 8.8 out of a mustang (1990) with new 3.55 gears and a refreshed posi> I plan to pull out the ring and pinion and trac loc carrier and install w new bearings etc into my 8.5 rear in my 1984 wagon. Any issue with this?
    Thanks!
    1984 Mercury Colony Park Wagon - 393 Dart block LS 91mm turbo with 4L80E and 9" 6.24@115 in the 1/8 mile (9's in the 1/4), 4650lbs w driver, AC, Drag n Drive rig 1300hp
    1988 Lincoln Town Car - stock for now
    no issues, the axel housings are the same. the difference is in the ring gear/carrier size.the 8.8 being that much bigger. aslong as you are swapping the carrier/ring & pinon at the same time, you will have no issues. even the bearings are the same for both diff sizes. I upgraded my 2.73 8.5 to a 3.73 8.8, in my lincoln this spring.
      only difference is the ring and pinion.......the carrier is even the same
        I don't think I've come across any 8.5's in my time...do they look the same as an 8.8?...or are they closer in relation to the old 2 or 3 year only WER rear end from the late 60's?
        -Don
        '85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
          great - so no tricky parts etc? Standard 8.8 install kit, stock axles and the 8.8 r&P and carrier will bolt right in?
            -Don
            looks just like an 8.8.......was used till like 83 iirc..........yrs ago when i grenaded the 2.73 tl in my 84 vic i picked up a 3.42 tl out of a 81 colony park and bolted it right in
              yep. as mentioned, the only difference is the ring and pinion itself. you can bolt the 8.8 ring and pinion in and use all the same 8.8 hardware. I think the traction lock that went in Slymer's car was actually out of a car with an 8.5 R&P.
                Guess I never really paid attention to them...learn something new everyday!
                  So out of curiosity, will a trac lok out of an 8.8 bolt into an 8.5?
                  -Phil
                    Yup. I did the swap in GMGT, my wagon and in my old mark VI.
                      just the trac lok carrier correct? not the ring and pinion? I want to keep my gears in and swap in a trac lok carrier
                      -Phil
                        I belive scottmang said the carriers are the same but, not 100% on that. It would be a great time for a gear set swap though
                          The difference is .3. You're welcome!
                            Its the same carrier.
                              Ohh wise guy eh?! :P
                              Thain-excellent, I know what I'll be looking for when we go to the junkyards at scottfest (Or sooner!!)
                              -Phil
