Checked the sticky but did not see it. Any idea what size the pitman nut is one the steering box?
Pitman nut size?
Pitman nut size?
Tags: None
I did mine recently (on a 2000 Grand Marquis), and it was 33mm. I'd seen people referring to 1 5/16" and 34mm, but mine was definitely 33mm. I have no idea if they might have changed over the years.
cool. I see if I have any of those sizes. If so I should be covered.
thanks Mike.~David~
Pipe wrench is a size?
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
meh... I just use a MONKEY wrench
