My cheap fix is no burnouts. Tires and gas are not cheap.
Wheel hop and what to do about it?
I did have some hop at first on my car. Shocks didn't do much to correct it. Seems 200 rate springs replacing the stock ones did the trick.sigpic
89 LTC 429>557 Cobrajet stroker
13 F-150 XLT 6.2 l
"If I could separate what's real from what I've been dreaming I could live to fight another day"
Thanks for reply's guys. Will try stiffer springs.“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -Anonymous
Get stiffer shocks to go with springs. Miss-matched shocks/springs don't do well together.
Like the others said, I'd quit doing burnouts. Besides tire wear and using more gas, it wears out the driveline parts faster too. Or, if you really want to do burnouts, pour some used oil on the rear tires and a bit in front, that'll get them started pretty well.88 Town Car (wrecked, for sale)
My solution to wheel hop has always been more wheel speed...lol...traction lock should fix that immediately...you might be able to do a 6" burnout afterwards.'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
My 5sp car has terrible wheel hop, enough to help grenade the rear. And that's with 200# springs, a t-loc and KYB's. The stock rubber bushings don't help and the flimsy control arms don't help either.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
let the clutch out slower, and with less engine rpm. it won't do that anymore.86 Lincoln Town Car (Galactica).
Originally posted by pantera77 View PostMy 5sp car has terrible wheel hop, enough to help grenade the rear. And that's with 200# springs, a t-loc and KYB's. The stock rubber bushings don't help and the flimsy control arms don't help either.'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
