Uca bolt?
    Uca bolt?
    Anybody know what size torx the uca bolts are?
    Thanks
    I think its a T50 bit. Don't know exactly what the bolt diameter and pitch is though. I'll guess M10 but thats really a guess.
      T50 is my largest & is too small....
        t55
          Thanks Mang!
          I'll get one this week.
            good luck removing the bolt
              yeah... I put an impact to it on my 88 and it didn't budge. that was 4 or 5 years ago now. still haven't changed those bushings.
                The uppers & 1 lower nuts are off & bolts move freely, ready to pull, however, 1 lwr is frozen in arm...
                  bigger hammer
                    sAWS all and about 6 blades
                      I thought about that...
                      I will need the arm though.
                      That is plan c....
                        iS THIS FRONT OR REAR?
                          rear. the front have normal bolts/nuts.
                            Thats what I thought rears. When that happens I cut both ends of the bolt not the arm. Use a hack saw most of the time as Sawsall blades usally go through about 4 to 6 of them per bolt. Its a bit more work but one blade will do several bolts if not all of them. Then melt/burn the bushing out.
                            Either a 9/16 or 7/16 bolt will fit dont remember which. Use grade 8 bolt or high grade stainless. Coat the bolt shank with anti sieze and use nylock nuts.
