11" drum swap and disc swap are effectively the same, its just a backing plate swap and some fairly minor re-plumbing. No need to swap the whole housing.
11" Drum brake upgrade questions
Guess I'll just stick with the 10" drummies. Which calipers & backing plates would I need for the disc swap though? Is a custom job or would things from a Mark VII work? Which proportioning valve would I need and is there a direct swap for the stock panther stuff?1985 LTD Crown Victoria - SOLD
Don't touch the Mk7 stuff, it's a disaster that you want no business with!
You can get the brakes from any '92-'97 aero car. Later '98-'02 setup can also work in a pinch, but the calipers will sit right on top of the axle. Buy new e-brake cables for the car that's donating the disc brake parts, but from the same donor car do grab the metal bracket that joins the two rear cables together as it's not available from the aftermarket.
Regarding the prop valve, you can leave your factory junk in place if you're feeling lazy and it won't effectively mess anything up. But if you're going with all new parts there's no reason not to use an aero master cylinder and bypass the box prop valve altogether - the aero cylinder has its valve screwed directly into its rear port.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Originally posted by His Royal Ghostliness View PostDon't touch the Mk7 stuff, it's a disaster that you want no business with!
Originally posted by His Royal Ghostliness View PostYou can get the brakes from any '92-'97 aero car. Later '98-'02 setup can also work in a pinch, but the calipers will sit right on top of the axle. Buy new e-brake cables for the car that's donating the disc brake parts, but from the same donor car do grab the metal bracket that joins the two rear cables together as it's not available from the aftermarket.
Originally posted by His Royal Ghostliness View PostRegarding the prop valve, you can leave your factory junk in place if you're feeling lazy and it won't effectively mess anything up. But if you're going with all new parts there's no reason not to use an aero master cylinder and bypass the box prop valve altogether - the aero cylinder has its valve screwed directly into its rear port.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostLoL, good to know. Have a buddy what wants to sell me a wrecked one for $600 and that was an idea I was tossing around.. What's the disaster part of it?
Oh, duh. Don't know why it didn't occur to me to think about those. So you just need the backing plates, associated hardware from the '92-'97 donor and that bracket?
"Factory Junk" lol. I'm certainly lazy.. So that's what that thing is on the master of those later cars. Sounds like I'd need to bend new lines too. Toss up for me now. I'm lazy combined with new house activities and making bets as to whether or not the pads will last through the winter or not. If all this house crap was out of the way I'd at least throw new shoes & hardware at it along with powdercoated drums by yours truly.
Powerdcoated drums are a waste of resources. New brake pads/shoes are not. Replace your frictions if in doubt, if you can't spend $25 on something that keeps your life and those of others around you safe than you really should not be driving anyways. Not trying to sound like a jackass, just well aware of how much damage what I drive can do, so not taking chances. Mine is getting an entire axle swap to gain superior braking, because more is moreThe ones who accomplish true greatness, are the foolish who keep pressing onward.
How is the engine in that Mark VII? What year? You can have an easy HO swap. ecm, throttle cables intake, engine, headers, lincoln trans has the higher shift point governor and IIRC the small Torque Converter as well as posi carrier in the rear.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Not all Mk7s have LSD rears tho...
Derek, me reread what you wrote (after some coffee ingestion), seems it's a lack of time to do car work that plagues you, not lack of funding. So I humbly retract my statement about the $25 pads/shoes, however the general point still stands - please do replace your brake frictions if you have any worries regarding their performance, even if it does mean you will have to sacrifice an hour of sleep to do so. I've actually seen them where the friction material separates from the steel backing plate when it gets low, that is certainly not a typical mode of failure but it does happen often enough to be a concern, especially with store-brand parts. Considering the damage that does to other components and the time it takes to fix the whole mess (fawk rotor replacement on factory box brakes!!!) it ain't worth taking the chance IMHO.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Traction lock was indeed optional. My LSC didn't have it.86 Lincoln Town Car (Galactica).
11" drum > 92-97 disk swap any day of the week
No need to hack together the parking brake cables
No stupid drum-in-hat parking brake shoe cluster fuck
No need to swap out the M/C and proportioning valve (yes the stock stuff works with disk but is far from ideal. Why "upgrade" your brakes if you don't want to go through the trouble of swapping in the proper M/C and proportioning valve?)
Honestly the stock drums are fine with decent shoes and properly adjustment.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Stock brakes are fine if you don't have to brake often or for prolonged periods of time, run them down some of the back roads here and things can get interesting if the driver is a flatlander
That said fuck drums! I'm in the process of combining several axles into one just so I can get away from those under-engineered disasterpieces and replace them with the largest most heavy-duty discs that can possibly fit inside my wheels - cause I want nothing to do with brakes that by design lose power as they heat up, nothing to do with them at all, not ever if at all possibleThe ones who accomplish true greatness, are the foolish who keep pressing onward.
Originally posted by jaywish View PostHow is the engine in that Mark VII? What year? You can have an easy HO swap. ecm, throttle cables intake, engine, headers, lincoln trans has the higher shift point governor and IIRC the small Torque Converter as well as posi carrier in the rear.
Originally posted by gadget73 View PostTraction lock was indeed optional. My LSC didn't have it.
Originally posted by pantera77 View Post11" drum > 92-97 disk swap any day of the week
Would need to buy a flaring tool for brake lines and that is on the list but we're still spending money on furniture and other malarkey so afraid to spend money on go fast and stop better stuff. I do think the stock garbage works pretty good. I've done quite a few panic stops that made my butthole pucker but didn't have to swerve off the road like the people behind me in their newer junk. Makes a bloke feel pretty good. Tap & die set would be cool too. As well as an air compressor and related junk...
The powder coated drums would be pretreated & powdered by meWhere I work has a few small booths since what we develop is used in conjunction with liquid & powder topcoats. We've got some nice Akzo-Nobel low gloss black stuff laying around.
Originally posted by His Royal Ghostliness View PostStock brakes are fine if you don't have to brake often or for prolonged periods of time, run them down some of the back roads here and things can get interesting if the driver is a flatlander2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Honestly the stock drums are fine with decent shoes and properly adjustment.I'm not completely oblivious to reality, I just choose to reject it when it doesn't line up with my opinions. (thanx Thain!)
The trans has the long tail. The governor is removable. Did not know limited slip was optional.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Mark VII trans is the same as the Townie trans, but I seem to recall that one being slightly whacky. Shift linkage is different, but nothing you can swap fairly easily.86 Lincoln Town Car (Galactica).
