Brake Line Size?
    Brake Line Size?
    At what point does one need to install larger brake lines? i.e. Big Brake Conversion or the Bigger Brake Conversion that was discussed a couple months ago; would the stock 3/16" brake lines work for '98 - '02 master cylinders (or aftermarket like Wilwood) and 4 piston calipers?
    98-02 cars ran the same 3/16 lines boxes have.
    never actually seen it explained why different cars got different size lines. You aren't moving any significant volume of fluid, so I doubt that aspect of it matters any. Smaller lines handle higher pressure just because of reduced surface area but thats the only difference I know of.
      Cool. Thanks Gadget73
      I replaced the front lines a few years ago; and I think I may be replacing the rear lines soon as they are fairly crusty for 15 year old lines :-/
        3/16" or 4.5mm line. Same stuff. The only time I've seen different sized lines would be from like the master to the HCU. But I think that was moreso a way to not mix up the lines on the car.
