Shake rattle and roll.............'86 MGM 5.0
    Not sure of the weather up in the "Big Apple" but it probably is not conducive to looking into it now. They are, when conditions allow, a good place to start.
      if someone unscrewed the fittings when the radiator was replaced, fair guess thats related. They have an O ring in there and when you rotate the fitting after decades the O ring tends to leak. it is possible to rebuild them but its sort of annoying, or you just get new fittings.
        Yes huge snow storm headed to the rotting apple, at least my Tudor will be buried under lots of snow which means I do not to move the car for street cleaning.........and also the snow hastening the rot all over the body:-(
          Thain I remember the fittings on the old radiator were leaking like crazy, very fortunately my bud had some new ones that he had in a drawer for like 30 years, also the fittings going into the trans were leaking.
            yeah they get leaky. Its a fairly crappy connector. Plastic thing to wedge the steel tube in place, single O ring to actually make the seal. Rebuilding them is just pull the plastic thing out, fish the O ring out, clean the dirt and crust out, put a new O ring in and put the plastic in. Easier said than done though, the O ring is halfway down inside and getting a pick to fish it out is sort of tedious. Last pair I did took me like 20 minutes, though I was working with my hand bandaged up from my own stupidity. New ones were out of stock everywhere though, and an engine swap was happening so basically it was either I get them rebuilt, or I'd have to dip into my emergency backup stock. I wasn't of much use with my hand wrapped up so I fixed the connectors. Used AC O rings too, because thats what I had. Handily anything you can seal with a common black nitrile ring can also be sealed with a green HNBR ring. I have those things fixing fuel line connectors on my diesel and as air solenoid seals on the Mark VII.
