TRANSMISSION ...
    TRANSMISSION ...
    will a 90 CV auto trans work and be a direct bolt in, in a 87 CV auto???
    Yes. Complete direct swap, absolutly no change.
      yes
        What happened?
        '90 Mercury Grand Marquis GS
        5.4L swap coming soon.
          Originally posted by N A
          What happened?
          well i might be geting a 87 CV with a bad tranny,
          i have a 90 CV that is running and driveing ... but just has body dammage... so i might use it as a parts car,
          i see in you SIG that you might need a tranny?
            Have a tranny shop put in a brass TV cable grommet!!! I learned this tip the hard way.
              why would i have a tranny shop do anything ??? i am going to do the work myself lol ... pay someone to do it, ha ha ha thats funny lol
                Most people don't know how to adjust the TV cable properly. You'll hurt your AOD within a mile or two if the pressure isn't set correctly.
                  Here's some info.
                  http://www.txchange.com/aodadj.htm
                  I hope you know what you're doing.
                    tv cable adjustments aren't that hard. Just adjust it per those directions and you'll be fine. Mine is set to be just slightly less than full pressure at WOT and its about perfect. If I adjust it tighter, it doesn't want to shift.
                      I go tmine to full pressure at WOT... holds the gears out nicely...
                      I miss dirivng GMGT
