Where to purchase separator plate gasket?
    Looking to tear into the AOD and replace a spring for the 2-3 shift as well as open the tail section and install a different governor for higher shifts. The kit I purchase was a trans-go AOD Hi Rev kit. From looking at the directions I need to remove the valve body and separator plate. I have a new pan gasket but need a separator plate gasket.
    Any ideas...also am I missing any gaskets I may need.....
    www.bulkpart.com transpartsonline.com
      There are two in there, one from valve body to plate, the other from plate to transmission. I forget which one Silverfox says to not install, but apparently one of them is crappy in the aftermarket version and causes more trouble than simply not installing it at all.
        I see an upper and lower within the links Jack provided.
          Ask 86VickyLX which is the one to skip. I don't remember. I know we skipped it on my Mark VII and it works fine. I do have the gasket, and laying it over the plate showed where the holes don't line up right.
            Gasket between valve body and trans.
              I purchased a bunch of stuff just to be safe. But it looks like John is saying the the gasket between the valve body and the transmission is the one to skip on.
                No manual?
                No balls.
                Originally posted by SVT98t
