Can an alternator that is overcharging cause battery out-gassing?
Battery out-gassing
Yes. probably easy enough to check voltage when running or just get a midtronics check at autozone or the like.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by Toploader View PostHow about determining the ability of the voltage regulator??What I Own: 1993 Mercury Grand Marquis GS
hook up a voltmeter and start it. If it goes over 15 volts with some throttle, its not working properly.86 Lincoln Town Car (Galactica).
Well the voltage regulator limits the output of the alternator so checking that the running voltage, without loads, is not too high in most cases would tell you the regulator is regulating the high end output correctly.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Gents I did two things today, I replaced the battery, and spent the afternoon washing down the "A" frame and steel under battery Fiberglas re-enforcement. I used up almost a full box of baking powder with water getting rid of all that white powder dried battery acid. I did not hook up my 1.25 amp trickle charger. In the spring when I return to the storage garage, I will see if she crank and starts, if not that's why I have a NOCO GB-70Then I will bring the car over to my bud that does nothing but automotive electric, to check alt output, and the condition of the vol regulator. Prestolite alts are notorious for being finicky........especially after 60 years;-)
If rebuilding is indicated, I may just swap in a Nippondenso alt from a 1988 Toyota Tercel. Many Studebaker owners have done this due to the constant problems with the original units. This also has the regulator as part of the unit. (REMY # 14341)Last edited by Toploader; 11-20-2023, 10:38 PM.
