Light bulb
    Light bulb
    What is this bulb name and number it’s from under dash
    that may be a 233 bulb. If it's not real bright, that might be it. 4W bulb.
      Mis-spoke previously. Do not the 233's screw in?
        Nope... mini bayonet.
          What’s a good led replacement for this
            where does this go? Only place I can think of which takes this kind of bulb is the lighter sockets. If thats the case and you actually use that lighter I don't think I would put an LED in that location.
              It’s to light foot board
                Year, make and model of car? Maybe we can look it up and then possibly get an LED exchange for it if one exists.
                  Ah... the finger burner up near the brake release lever? I remember the Mark VI used the bayonets in that spot instead of wedge bulbs like later cars. I can't find for sure what size bulb goes there.
                    1987 Country squire wagon
                      Towncars use a bayonet base up there but the base is the size of a brake light bulb. Bulb itself is smaller though. This looks much smaller, like the cig lighter bulbs but I'm missing some scale here.
                      anyway if its the size of the brake light base, you need an LED sub for an 1156 lamp. Thats the single contact type. I swapped those in the Towncar and the Conti years ago, better light output, no more burned hands. Works in the trunk and hood light too. I think Ford/Merc stuff typically used a wedge bulb there.
                        If that's the case, then it's a BA15S bayonet base... Lots of small bulbs to fit that. 67 seems to be the correct number for that location though. 8W incandescent. So looking for a 12V BA15S 67 LED will probably get you a lot of options.
                          I think that also may be the same as the ditch light bulb
