Hmm. Makes sense. Where do I get one? 87_Crown_Vic, how did you bypass your heater core?
What the hell? Chronic Overheating now???!!
Originally posted by gadget73 View PostIs your fan clutch good, and is the thermostat opening? If the upper radiator hose is hot, then the thermostat is opening. How was the heater core bypassed, or is it still plumbed in? Have you burped all the air out of the system? Normally what I do is let it idle with the radiator cap off, when the thermostat opens, the level drops. Fill it, put the cap on, and fill the overflow. It may get a little hot and bubble in the overflow, but once the engine is shut down and allowed to cool, it should draw coolant out of the overflow to replace the air that came out.
Originally posted by LtMercDaddy View Post
after the radiator cap is back on, rev the engine a few times and watch the upper and lower rad hoses, check to see if they are collapsing under increased RPMS.
Its got air in it. The hoses collapsing is from the engine cooling down and the air contracting. Fill the overflow bottle, it should suck coolant up from there. If not, pop the cap and top the radiator off.86 Lincoln Town Car (Galactica).
