R134a Conversion
    OK, thanks
      say john did you ever ask anyone else on the site weather or not that hissing is normal when the car is running? I'm curious to know about that.
      -Phil
        No I haven't. Does anyone's A/C hiss when it is shut off for a little while?
          Vacuum leak it should be the vacumm canister or the soup can Getting mine this weekend
            it could also be the check valve
              The car is off. and it's still hissing????
                yes, they hiss for a while till the pressures equalize after its shut off.
                  Ok thank you so much Gadget. I was getting worried.
                    I have a quick question thats sorted of related you might be able to help me with. I have the 134a conversion done. New compressor, evaporator, accumulator, lines, and its properly charged and holding. The thing is, if you turn the A/C on, the compressor will only come on it you fiddle with A/C WOT relay (unplug-replug halfway kinda). Jumping the clutch cycling switch didn't work, the old relay was tested and worked but it still did it when swapped with another spare A/C relay, a brand new one, and the connector for it was replaced as well. Is there a another sensor I'm missing for the A/C system that might cause the relay to get power. The car's not showing codes and the TPS is new and I thought that relay only got power at 80% throttle. Thanks in advance.
                    1986 Grand Marquis LS 2 Door
                      the WOT cutout relay shouldn't get any power to it's smaller connectors when the AC is operating. The relay is powered by the ECM at 7/8 throttle to cut the AC out. Sounds like its being triggered improperly, maybe a bad TPS or something.
                        Did you try replacing the wiring that connects to the harness? 87_Crown_Vic had a similar problem with his fuel pump relay. It wasn't the the relay, it was the wiring for it.
                          Yep, I replaced the harness, used the old relay, a spare, and then a brand new one. I think I might redo the soldering at the connector and see if that helps any. I know the wires are in the correct spots as I swapped em one by one but that'd never hurt to double check. I was just hoping there was a low oil/pressure switch for the A/C I might have been missing. These relays are definitely being a pain these days, the cover for the other one accidentally went upside under the closed hood but took water during a heavy rain and shorted/fried the fuel pump relay which I thought killed the fuel pump because it was running and running til the battery died. My Dad and I tested fuel pressure at the rail and what we thought was the relay which tested good so I now have a brand new Bosch fuel pump when it was just a bad relay. The problem was I replaced both connectors but they only had the green plug ones so it was just a dumb mistake, but I've got a very quite fuel pump and working spare now. ahh
                            I've had the AC working some here and there. The problem is the relay itself, everything works fine otherwise. The problem I'm having is getting the proper relay for it to keep working. I have two Standard Motor RY68 relays but they have 3 little pins and two larger ones. With them I can't get the AC back on. I popped in a ford E5----- relay and has three small pins and one larger pin and it worked but it burnt out, and the other E5---- spare would probably do the same if I keep kept using it. I'm gonna keep looking for a Ford one in the yard but in the end I may end up just having to wire in a Bosch one. Does anyone have the part number for the A/C WOT relay I need (oem or aftermarket), I been through so many I lost track of what was in there to start with. Also does anyone have a diagram for the relay, I can't seem to find the info in my EVTM, Helm/Ford, or Haynes books. Thanks again.
                              Dy-886
                              F8pz-14n-135-ca
                              motorcraft relay that's the one I got when I replaced it 2 years ago
