Well yesterday my left turn signal started to act up... it was clicking real fast... with no lights showing... So I checked the bulbs. all fine... Then I noticed the brake lights weren't working... backed up in front of Advanced... Noticed they were not on in the reflection, off the windows on the front of the building... So I checked the fuse... sure enough, it was blown... replaced it, the left turn signal started to work, and the brake lights worked... So I pull out on the street, and the left turn quites working again... and the four ways are out, So I know the brake lights are out too... By now I am on the way home, on the interstate... So i very carefully drove home... To keep someone from running over me... since I had no brake lights... So I went to my Advance here in Gulf Breeze, and got a stoplight switch, figuring the stop light switch is shorting out.. and go over to my mechanics shop... (I didn't feel like being a contorsionist last night, trying to get under the dash!) he told me that the stoplights on the Ford Crown Vics are routed thru the turn signal switch, and he checked the stoplight switch, it was fine... So I took the stoplight switch back, and ordered a turn signal switch... It came in this morning... so today I put it in... I also found a loose wire in the plug... The wire snaps into the back of the plug, but this one was coming out of the back... Not sure if it was because of me pulling the plug... Or if this may have been causing problems.. So I glued the wire back into the plug, so it would not come out again... Works like a charm! I also didn't realize how faded looking the black part of the switch looked... So it looks like new now!!!
Also, since I had the column apart...
I fixed the rattle on my shifter... I installed a thin flat washer as a shim, to take up the slack in the area around where the shift pin goes in... and also applied a liberal amount of grease to the end of the shift lever before putting it back in... No more rattle! (I HATE rattles!)
So if anyone has a problem with your turn signals or brake lights... or a combination of the two... replace the turn signal switch... As a plus... the chrome was starting to come off of the end of the knob where you twist it... cut myself one about 2 weeks ago... solved that problem too!
Tom!
Tom!
