All my cars have carbs, actually. Hm ... kid's taking a nap break right now, this would be a good time to test 87cv's claim.
Gas Gauge
Back from the garage. Big surprise, the potentiometer behaves like a potentiometer. Fuel gauge reads the same given the same armature position when wires are reversed, provided that the body of the sender is not grounded. When the body of the sender is grounded, the gauge reads correctly when connected correctly, and reads Full regardless of armature position if connected backwards.
Fact: Sender plug consists of two wires, one signal wire and one ground.
Fact: Fuel gauge reads over Full if signal wire is connected directly to ground.
Observation: on at least some older Ford fuel level senders, only the signal wire was used. This is because that in most installations, the steel tank is effectively grounded to the steel chassis (such as in first-gen Mustangs where the tank bolts directly to the trunk floor), and the steel sender body is in turn grounded to the tank. Hence, no theoretical need for a redundant ground wire going directly to the sender.
Postulate: The ground wire was added to the normal sender circuitry to make the fuel gauge more reliable, in the event that a tank attached by straps (such as ours) happened to be inadequately grounded or there happened to be an inadequate electrical contact between the sender body and the tank. It's simpler to connect a ground wire directly to what needs to be grounded, rather than worry about whether the sender is adequately grounded via its retaining ring.
Prediction: If your sending unit happens to be adequately grounded to the vehicle chassis, reversing the wires to your fuel level sender will cause your fuel gauge to read Full regardless of how much fuel is in the tank. If your sending unit happens to be not grounded at all, your fuel gauge will read Empty. In some cases, the resistance between the sender body and chassis ground could conceivably be between 73 and 10 Ohms, and in such cases the gauge will read somewhere between Full and Empty. There is NO correlation between gauge reading with the plug reversed and the position of the armature, and this procedure does not test the function of the sending unit.Last edited by 1987cp; 04-15-2009, 12:02 PM.2012 Mazda5 Touring | Finally working on the LTD again!
nice write up! Allright well thats what i needed to know, at the very least i can test to make sure my fuel gauge will go all the way to full. and from there I can begin taking the sending unit out. Thanks to both of you!-Phil
very nice 1987cp~David~
Originally posted by 1987cp View PostBack from the garage. ....86 Lincoln Town Car (Galactica).
Originally posted by 87_crown_vic View Postif anything, it would let him know if there was a bad wire or gauge was bad... when reversing it it will at least show that things still work and narrows it to the sending unitGive a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
Well I was driving around yesterday and I looked down and my fuel gauge is working all of a sudden....so im now guessing its wiring, I allready bought the float and stuff, i wonder if i can return it. I'll have to check it out, haha. Opps-Phil
keep it..you may never know when it will actually shit the bed....but it is sure nice to have money in the pocket.~David~
Like I mentioned there should be some orange box under the glove box that should work with the gauge, or maybe it's just the light. If it's only for the light, which you don't have a fuel light, that box won't be there. Could someone verify this for me??
The box is for the light. It should actually say Low Fuel Module or something to that effect. Mine is actually black, and lives next to the gas pedal though.86 Lincoln Town Car (Galactica).
Must be different on a Grand Marquis too because I looked behind the dash and couldn't find it. Does anyone know where it is on an '88 GM?Nick
88 Colony Park LS
