My right flasher isn't blinking...any idea what's wrong. I changed the bulbs.
Right Flasher Not Blinking
The actual signal outside or the indicator light inside?sigpic
make sure you've checked ALL the lights. there are two in the tail light housing. I thought I'd checked them all, but someone (1987CP?) told me to double check, and sure enough one was dead in the tail housing even though it wasn't obviously out.
Originally posted by 1987cp View PostOnly the right side, eh? That'd rule out the flasher, so it could be either wiring or the switch.
Do the four-ways flash correctly? If so, that should rule out a bad ground.sigpic
New 87 LTD Crown Vic
That would be the multifunction switch on the left side of the steering column that sort of controls the turn signals ....
I readily believe that your indicator isn't blinking, but is it coming on at all? For example, the typical "bulb out" behavior where the indicator comes on steady when you pull the stalk up?
Still waiting for an answer about whether the hazard flashers work ....2012 Mazda5 Touring | Finally working on the LTD again!
