OEM heater core
    OEM heater core
    Are heater cores for boxes still available? I think mine is leaking ( I can smell coolant when I first turn the heat on, the window gets a little foggy from time to time and I'm slowly losing coolant), and I want to replace it with an OEM component if possible. Also, is there a DIY somewhere around here for it? Thanks guys.
    Nick
    88 Colony Park LS
    They certainly exist. I have one on a shelf at home in case I ever need it. Bought it from RockAuto.com
    There's no real DIY for it around here because it's such a long job (don't know how many hours but I have heard 7) but we have some experts on the Panther heater core job. Are you far from PA? Scott can do it for you and it'd be way cheaper than a garage and much less murder-inducing than doing it yourself
    Did any passengers get a foot coolant bath?
      I have the same question. Mine has been shot for a while now. I just need a good core to put in along with my restrictor and I should be good to romp on it again. I am calling ford tomorrow to see if they have one in stock somewhere. I know that it will be at least 80 bucks for an oem one though, but I dont care at all.
        Just to give you guys a heads-up. It is a full day job, but it is not hard to do.The manuals tell you to removwe the WHOLE dashboard, but that is not the case. I can'tsay for sure, but I believe there is a couple of post on the job.You could try SEARCH, but I've personally have never found anything I was looking for.
        MIKE
          I have done it before Basically what I do is overkill just because I do not want to scratch or mess anything up. I remove the dash pad (I have an 87CV) remove all of the trim on the dash board, remove the glove box, the speedometer, the kick panels, passengers side seat, steering column covers, drop the steering wheel. Unbolt the the bolts behind the kick panels, the one directly above the steering column, all screws underneath the dash pad that hold the physical dash to the car. Then pull the dash away, unbolt the core box from the outside and inside remove the core hoses as well as various vacuum lines connected to the bled box and then pull out the entire box.
            yes, they're still available new. I got one about a month ago.
            If you're doing the heater core, now is a good time to fix broken air doors. If air comes out of everywhere, and doesn't switch from floor to vent to defrost properly, the hinges in the air plenum are probably broken. You have to unbolt the air plenum to get the core out anyway, so you may as well pull it all the way out and take it apart to fix the broken doors. Some small hinges from the hardware store, and a little creative engineering should get you back in business.
              what he said
              89 gets confusing because they used two different heater cores that year......at some point in 89 they switched over to an aluminum core
                Thank you guys. I'm gonna try and nurse it along until warmer weather comes along and the bimmer is done. I want to use a genuine Ford part just for the peace of mind knowing I most likely will never have to go back in there again.
                Nick
                88 Colony Park LS
                  Did a heater core job on mine last august or sept had no problem getting a core at O'reilly. Labor intensive but not impossible job to do.
                  NA-15.78@91.21, 80hp shot-14.48@96.21
                    i will never install an aftermarket heater core in a ford.......i hate doing the job multiple times
                      I bought one from autozone in 2007. It died on me already in the middle of 2009.
                        Ive not had to do one on the ford, and hopefully won't have to, but had to change the core on the 85 olds, that was a 2 day affair.
                        1985 GMC 1500
                          okay ordered one. 75 bucks down the hatch. Funny thing is the autozone one was only 20 in 2007. But at least I will have FORD one now.
                            installed one from advance in 2003 in my towny was 12 bucks with my girlfriends discount.........it's been making random stinky since around 2006
                              The one I bought isn't Ford or Motorcraft, I don't think. It was only about 50 or 60 on RockAuto....should I get rid of this one and put a MC one in?
