Found a vacuum gauge in my tool box, what do you know. Not sure where/when/how I got it
Anyway, figure I'll hook it up and knowing the vacuum could help me diagnose my rough running rebuild.
What SHOULD vacuum be?
If I misplaced a vacuum line or left one open, I presume vacuum would be weaker-- what sort of range would suggest a vacuum leak then?
If I had a smoke machine, that would be best, but, I don't
Finally, more just curious. I looked, and indeed, sunpro sells a vacuum gauge to put in your car's dash. Probably not something I need regular input on though?
Anyway, so it looks like they're really sold for people running boost, turbo/superchargers.
Which got me thinking... when the engine sucks in air it creates a vacuum, which drives all sorts of things. But if a supercharger rams in air, it creates HIGHER pressure.
Does this mean that if I ever supercharged my station wagon, with boost, I'd play holy hell with everything that depended on vacuum to run? Can boost be high enough to even override vacuum (keep in mind I have NO idea what numbers are normal for boost in psi, and what numbers are normal for vacuum. If normal vacuum is -40psi and boost not more than 10psi, then you end up I presume with -30psi going to all your vacuum lines...?) (maybe not that straightforward).
