Instrument Panel lights on Auto Lamp not working...
    Update: Fixed the AutoLamp issue....
    Yep, it was just the AutoLamp relay. I bought a Standard RY-133, which interestingly, had the Ford OE part number on it. I called the folks at SMP and they said that for this part, Standard actually buys up NOS Ford. Ford must've made hundreds of thousand of these. Now all the lights come on and go off correctly (not just the headlights). That relay has a switch for both headlights, and separately, the other exterior lights/instrument panel lights.
    95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
    96 Buick Roadmaster Limited Wagon, mostly stock
    77 Ford F150, 400M auto, longbed
    98 Suburban LS 5.7L Vortec, stock
    90 Grand Marquis, stock
