If you're moving and you're not using any gas, that's enough for the tripminder to calculate your fuel economy.
Hign Mileage On Tripminder
Got a spare harness but it only has 3 connectors (Power, Dimmer and I guess either VSS or Fuel) so can't tell yet what's up. Need to get under the dash to see what is in the car and I'll report back! Thanks so far for the info!!
The one in the plastic/rubber thing is the vss and fuel flow wiring. That plugs into the wiring under the dash. The other one plugs into your cruise control servo, so you can still haz cruise control (standalone cruise control 83-87) The vss wires are green with white stripe (+), and black with white stripe (-). Fuel flow is in same connector BLUE WITH PURPLE STRIPE. You are most likely missing that wire in the connector under the dash...
What I will do is to separate the connectors and report the wire color combinations of the two trip harness connectors (just the ones by the E-brake) and the two that were already in the car. Then we can see what we have! Wonder if you can coonect the wrong conectors together or if they are "keyed" so you can't?????
Originally posted by miamibob View PostWhat I will do is to separate the connectors and report the wire color combinations of the two trip harness connectors (just the ones by the E-brake) and the two that were already in the car. Then we can see what we have! Wonder if you can coonect the wrong conectors together or if they are "keyed" so you can't?????
You have the right connectors under there, you're just missing the one wire for fuel flow. You have to run that wire from the pigtail on the computer harness, am I gonna have to call you and personally explain to you what needs to be done? :p
Alright. Go under the hood. Look on the drivers side of the firewall, behind the cruise control servo. That's the circular thing bolted to the inner fenderwell. Behind there is you computer plug. It has a 10mm bolt in it so you can't miss it. Coming from the main plug is a little pigtail with a single wire round black connector. This is your fuel flow wire. If the pigtail is not there, you will have to remove the connector from the computer and add the wire to pin 34 of the computer's harness. Regardless, you need to run that through the firewall to the female connector under the dash (the one you plugged the tripminder harness into). You should then have fuel flow.
Funny you should mention a black wire with a little round connector. There is one right behind where the trip gets mounted but it has a connector that appears to take a bulb (194?). Probably not talking about the same thing but just checking...I will check the info you gave me and THANKS! Bobby
Yes, I do remember a thread about this, with photos, but it may have been an older car. Not sure if wire color/placement is the same in mine.
Originally posted by miamibob View PostYes, I do remember a thread about this, with photos, but it may have been an older car. Not sure if wire color/placement is the same in mine.
The black connector I'm talking about is under the hood...
