Did any of these cars come with either of these options? I can see from the pictures on here that you guys have some really nice cars. I'm sure that after all the mods that have been added that you might want a security system to protect them. I interested in adding an aftermarket alarm with keyless entry, probably a viper system. Have any of you guys installed anything like this on your cars? If so, how hard was the install and were you happy with the outcome?
Alarms/keyless entry
some came with keyless entry (keypad on the door) but only aftermarket for alarms until the mid to late 90s I think.
Wiring in a system to a car without can be rather a PITA. You'll need to take half the dash apart and the driver door as well along with running wires to and from stuff. Done right... it'll last a long time though and serve you well. You will need an electrical manual for your car to even start thinking about this though.
Mine did not come with keyless entry from the factory. Luckily I have a good friend in the business that does this kinda thing professionally and he said these cars aren't too bad. I picked out a good system (Viper 5701) that I'm going to install. I got my hands on the vehicle specific wiring diagram for my car from my friend that includes what color wires I need and where they are located. I also have the installation manual for detailed diagrams and instruction for the viper system. I'll be getting into this probably at some time next week after I look everything over with my multi-meter to double check that the vehicle wires actually are what they are supposed to be. I'll post back with some pictures documenting the install and maybe a video when it's completed. Wish me luck lol
nice... looking forward to it.
1988 MGM GS - Preferred Equipment Package 172A; InstaClear
1994 MGM GS Montigua
2002 Mustang GT Coupe
I have added a Viper keyless, alarm, and remote start system.
It isn't too bad, besides the fact the the majority of the wires coming from the alarm system aren't used in the older car. so there is a lot of tucking away involved. The hiding and routing all the wires was definitely the worse part for me.
Also when i installed mine, the viper system I bought controlled the locks with a ground pulse and my car needs a positive pulse so relays were needed.
Other than sorting through the wires and tucking them up above the glove box it wasnt too bad.
Also I would recommend a system that has a 2 way transmitter so if your car is getting messed with it will send an alarm to your keyless remote.
I got mine for 45 bucks off ebay, it was a $200 system so the fact that I needed relays wasn't too big a deal1985 LTD Crown Victoria - Currently restoring after she caught fire! CFI to SEFI to Carb swap, all custom wiring, Duraspark 2 ignition, Motorcraft 2100 Carb, slicktop, Shorty headers dumped before rear axle, 140 Speedo, 3G alt, And currently building an engine for her.
2000 Lincoln Town Car Signature Series - 165XXX, PI intake swap, 30 MPG Easy on the Highway
, All options except dual exhaust. Currently looking for 2 front seats: Heated, Memory, and Light Graphite color!!
Originally posted by fmansfield444 View PostI have added a Viper keyless, alarm, and remote start system.
-Rob
Sent from my SGH-T889 using Tapatalk 4
if you have a distributor and regular coil... it's the wire that goes between the coil and the TFI (Ignition) module.
Yep I tapped into the negative coil wire before under the hood. I forget the color but it's where sly said. I am not sure of a spot in the cabin. But since you have a tach it should be there somewhere. I'd guess behind the cluster somewhere.
Can you not tap into it under the hood and then tuck the wire inside the loom with the factory wiring?1985 LTD Crown Victoria - Currently restoring after she caught fire! CFI to SEFI to Carb swap, all custom wiring, Duraspark 2 ignition, Motorcraft 2100 Carb, slicktop, Shorty headers dumped before rear axle, 140 Speedo, 3G alt, And currently building an engine for her.
NO GUARANTY on this.
Looking at a factory 89 EVTM, it looks like the DG/Y wire from the ECA to the coil might give you the signal at the firewall. There is a resistor in-line taped to the harness just to the right (facing the engine) of the distributor. I am not sure if the signal you get close to the firewall (going in to the ECA) is strong enough for the alarm given the resistor.Last edited by jaywish; 09-11-2013, 11:47 PM.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Ok got tje tach all wired up from the coil an ran it through the fatory loom. I thought that was the last of my conmections and when I attempt to rwmote start the car the remote sounds the correct sound and the car does nothing. Are there any others that have installed a Viper remote start successfully? If so I'm in desperate need of your help. Just as a note, this is the viper 5701 2 way alarm with remote start/keyless entry. I think this may warrant a new thread at this point but I just though all this info would be best kept together.
Ok, scratch that last post. Finally have the viper 5701 all wired up correctly and now have an alarm with keyless entry, remote start starter kill circuit that all reports back to me on a 2 way key fob. Everything is soldered and heat shrunk so I will hopefully never have to deal with that huge pain in the ass of an install again. Thanks to all who helped me get through this install. It's such a relief to be done with it and finally feel safe about being able to park my car in New York City.
