Hello everyone,
I've got an '88 townie with a analog dash and a pod with 9 dummy lights to the left of it. My girlfriend has an 89 which has the exact same set up. When you flip the key to run (I always do that to prime the fuel system) the check engine light, along with many others are supposed to come on. All of mine come on EXCEPT the yellow check engine light, which is on the middle row, right side. Her car's light DOES come on like it is supposed to. I went to the junk yard and tore apart one with a digital dash to get spare light bulbs since I figured mine was burnt out. Once I took my car apart I swapped the light bulb that was in the check engine slot to the one for the door slot and it still didn't work, so the lights aren't the issue. With the engine running I even tried unplugging things underhood to force it to come on. That was dumb. The light didn't come on and now the car's idle surges a bit as it calms down when started cold. So, is my pod bad or is my car just weird? I read other posts around here where people say that only the 89's got the CEL yet my car has it too. Perhaps the computer isn't programmed to light it up? Also, my car appears to be an early 88 model, the core support is dated Sept. 1st, 1987 and I've noticed that the plugs for the speakers and such are like what my '85 LTD had. What gives?
Thanks for reading and I appreciate all input!
Derek
Derek
