I've had the fuel pump relay go out a few times. This morning it happened again, or so I thought. I cranked the engine and it didn't start.
Pulled the relay and plugged in my trusty jumper wire to hot-wire the pump. I didn't hear it come on. Uh-oh. Tried starting anyway to no avail.
Pulled a spark plug wire and verified that I had spark. Got a ride and called a tow truck.
Once I got it home I hopped in and turned the key. Fuel pump on, engine starts. FML. Tried it again, no pump, no start. Tried several times with intermittent failure/success.
Pulled the relay and checked voltage at the switching terminals in the harness plug. With the key on, i'm getting about 1.25 volts. With key turned to "start", it jumps to about 3.6V. Shouldn't it get more than that?
Would this possibly indicate a bad ignition switch?
I connected the relay itself to 12V and it switches every time. Out of curiosity, I connected it to a 1.5V AA Duracell battery and it did nothing.
I plugged the jumper back into the harness plug. Now it makes the pump come on EVERY TIME. So I guess there is a chance I didn't plug the jumper in properly, prior to the tow. If that is the case maybe my fuel pump is OK.
