A/C not blowing as cold as it should
    Could be anywhere. I've had a lot of trouble with leaks at the charge ports, but any connection points are a possible issue. I've replaced a condenser in my Towncar, John has done several evaporators. I once had a compressor lose a shaft seal. Basically it depends, you just have to seek and destroy the leak.
    This... everything has been replaced on my 93 except the evap and hoses (oddly enough). This includes all the seals.
      Yeah, I guess I could suspect the charge pots (Schroeder valves) but with he dye going in it, it will almost always be covered in the dye regardless.
      -1973 Volkswagen Bus Westy
      -1986 Honda Magna 700cc
      -2011 Subaru Outback
        have to wipe them off after charging with the dye. If more comes out, then you know.
          Figure out when you want me to look at it, Andrew.
            You may have a partially plugged radiator and that will make the exchange of hot air for cold air inefficent so if you have minerals in your tap water it will plug the radiator. I had a simmiler problem I just changed the radiator and it is problem solved.
              John, I will.
              Rodent Killer, do you mean the condenser or did you really mean radiator?
