One thing I’ve noticed with all my radio swapping I’ve done is that none of them had working illumination. In the sunlight you can see the numbers but that’s the only time. Last time I pulled the radio I tested for 12v at the illumination wire and get nothing. Has anyone else had this issue before? Everything else works.
Also what does this connector go to?
It’s next to the hvac panel.
