When I had tried if sealing up the brass housing works (before I had found my plunger) I had tucked a small pice of neoprene inside the hollow stem. Sealed up perfectly but did not work, of course.
I do however think the plunger needs to be free for motion. If it only should stick out why in the world did they make it a costlier, moveable two-piece design instead of just a needle end on the brass housing like a carb needle?
My sensorīs completey reassembled now so I canīt try that for I fear the bent end of the spring wonīt stand another straightening. It will sure break off.
Maybe you can try that Lutrova? Could use a piece of wax instead of the neoprene, too. This is just for testing so the wax wonīt hurt and could be melted out with a hot needle.
And yes, the "drifting" sounds like the plunger not seating correctly. I do think that the ultrasonic cleaning will help here since mine was prefectly clean inside. No debris or dirt tracks at all. Have not seen a non-cleaned disassembled though, so I canīt thell if theyīre clean or dirty inside normally.
BUT from how dust loaded the bimetal was (and is on my donor car one) I really think that the exact dust adheres and builds up inside the brass housing. And that can prevent the plunger from fully seating into the valve body - making it stick/bind/ not move correctly.
