HO upper intake plugs
    Here's how both intakes look from the under side, notice the brass plug and the vacuum T-ee on the bottom of the HO unit:
      very odd... I have never seen a stock upper intake like that. How is the stock, lopo manifold plumbed for the PCV?
        Hm, well all of the stock (non-HO) uppers I'v seen are like that. Even the '86 Mark VII that I found yesterday in the junkyard had such an intake, althoight the cover plate on top of it said "5.0 HO". Vacuum ports on the stocker go like this:
          My stock upper had no plugs under the intake, the HO one does. I plumbed it like an HO and looped the vac line from the center of the intake, down to the T over the VC, then to the PCV. The non-HO one just runs vacuum direct from that larger port in the center of the intake to the PCV valve. You can plug the HO or just swap the T and the pipe plug and re-route the vac line. It makes no real difference.
            It must be a Lincoln thing then. Every 5.0L CV/GM, Mustang and T-bird I have worked on has had the same fittings.
              Well, I'm pretty positive the Crown Vickys and MGMs get the same "smooth" intake, but I'll check next time I go to the junkyard. For now, here's how it turned out in my car:
              Nothing fancy, but it works, and makes some difference in performance I think.
                interesting... what throttle cable and TV cable did you use ?
                  The EGR spacer, the throttle body, and the three cables with the mounting bracket are all off a junkyard Mark VII.
                    Whats with the end on the TV cable?
                      About the TV cable - I don't like or trust the plastic thingie, this setup is much strogner and reliable (look in the tranny info sticky topic). Adjusting it is a bitch, but once done it ain't gonna go anywhere.
