So I am attempting to reinstall the hood and got it bolted into place; but the hood hinge(s) seemed to be seized in the up position. I have had it soaking with WD-40 (it's all I have at the moment) for a few hours. Has anybody dealt with this issue? What would you suggest is the solution? I am going to do a few things and then go back out there and work it a little. If all else fails, I will pull it back off and leave it by the car until the next attempt.
Seized Hood Hinges
Try CREE OIL or PB BLASTER. Either should work out well to lube further once you have them moving better!Originally posted by packman View PostSo I am attempting to reinstall the hood and got it bolted into place; but the hood hinge(s) seemed to be seized in the up position. I have had it soaking with WD-40 (it's all I have at the moment) for a few hours. Has anybody dealt with this issue? What would you suggest is the solution? I am going to do a few things and then go back out there and work it a little. If all else fails, I will pull it back off and leave it by the car until the next attempt.Last edited by friskyfrankie; 05-26-2025, 10:00 PM.What I Own: 1993 Mercury Grand Marquis GS
CRC knock'er-loose is another penetrating oil that should work well. I personally use PB Blaster because it's what I have on hand and is easy to get most places around here.
It freed up. Just went outside a few minutes ago and worked it a little until it creeked loose. I didn't lower it all the way; just a little and raised it back up. I relubed it with WD-40 and will come back at it in a few hours. I was not wanting to haul that hood back in the basement; despite it being much easier to handle with the hole cut out of it. This is good as I no longer will need ply wood to support the tarp; just something to go over the hole in the hood.
As such, I was using PB Blaster too; but I have one can with a little product left in it; but no pressure to spit it out. Thank you for the suggestions and sorry for the panic thread
