Mine is retained by a big bolt in the center (I think). I can use the wheel puller?
'79 '82 Steering wheel repair write up..
Originally posted by 86VickyLX View PostMine is retained by a big bolt in the center (I think). I can use the wheel puller?2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View Postnope, '79-8x was splines, after that it changed to a mostly-round thing with two flat sides. Early ones are retained by nuts, later ones by bolts..
