So take #2 and I found the artists rendition of the door - in the Ford shop manual (big black binder) - to remove the air vent window unit. I had to re-read the directions aloud several times as I was trying to figure out a) the diagrams and b) how the directions or diagrams didn't match my car.
It said to remove the window regulator bolts to the inner door panel. Well, there is no regulator mount, just some punch-outs in the metal where it should be.
Screw #2 to remove the external dew wipe is holding the bottom of the vent window in its place, then remove the rubber "gusset", regulator (coiled spring) and ease the whole assembly out with soapy water.
I stopped once I realized what it was asking to do. It was asking to lower the door window all the way, and to shift the metal window channel between the vent and the main window a bit to angle out the vent rubber. I'll wait for next week to tackle this. I wonder what else differs from the manual.
The same shop manual mentions two CV models, "Lo" and "K" models.
