Alright, so last week I was asking about door locks, which do continue to frustrate.
I never did find the "right" kind, dorman seems to already be the best name around (I was hoping to find better...), so the fact that the dorman actuators are not doing the job,
I am now attributing to sticky latches.
Especially the tailgate. Sometimes even my human muscles have a difficult time getting it open! Let alone the poor little actuator.
In fact, one of my actuators might still be good. It still operates, and does not feel seized at all! I might just leave it alone. But, it could not lock or unlock the door in a single stroke.
Sticky latch? I'm thinking so.
Alright, so how do I go about servicing one of these things?
Option a) is to try to pull them out entirely. Finagling the door lock actuator was hard enough however, with those blasted z-shaped ends-- how hard is it to disconnect the inside and outside handle control rods?
Option b) is to try to just spray in wd-40 or another penetrating oil, followed by a lubricating oil, or maybe fresh white lithium grease. I don't think that'll be enough.
I'm wondering if I might safely blast them with a pressure washer, soaking a lot of things, but will it short out wiring harnesses and power window motors and rust out the inside of the door? What about if I give it some time to dry?
Now, if I do remove the latches, do you think overnight in a shallow pan of wd-40, or vingear, or even lime rust remover? Followed by a blasting with the pressure washer on the back patio, then let to dry, then thorough smearing with white lithium grease?
And then my actuators might be able to do their thing, and I might be able to open my tailgate without herculean struggle?
![:-)](https://www.grandmarq.net/vb/core/images/smilies/smile.gif)
