Flat black front end.
    I started to paint my car using Rustoleum flat black paint. I used a roller and brush for the tight areas. I might do brushed trim to kinda tone down the contrast. It will be nice to have the car one color.
    This is just the front end. I will be doing the whole car, just need the weather to cooperate.
ID:	1302829Click image for larger version
ID:	1302830Click image for larger version
ID:	1302831Click image for larger version
    1990 Colony Park, with HO swap.
    Previously:
    1990 Lincoln Town Car Cartier.
    88 CVLX
    01 Marquis
    What did you use for the major areas? Brush/roller? Looks good! Wonder how it will hold up...
      Roller for almost all of it. Just used a foam brush for the trim spots
      Previously:
      88 CVLX
      01 Marquis
        Looks good. Could look even better if you take some time and remove the pieces of trim around the windows and door when you get to these areas. Also getting the trim off the hood and the ditch lamp bezel is just a couple of screws.
        Are you getting rid of all the trim? How did you fill the holes?
          I took the headlight bezels out. I'll remove the trim from doors and put back. Not putting the effort into filling holes etc.
          Previously:
          88 CVLX
          01 Marquis
            Nice! I rollered & brushed the paint on my Dodge back in highschool. Yours came out much better than mine did. I never had any issues with it not holding up though except where I put it on too thick.
            Should look really good once you get the whole car done
