well i havent put it on yet but im not looking forward to it, it will probly be a pita
Dave's Hot Rod '84 Merc 2 dr
well I finaly got one,,, yep a 4 bbl intake, $35 off a buddy of mine, and i had the holley 4 bbl carb laying around, will probly have to be rebuilt but oh well i finaly have one,,,:megadeth: the intake is a ford aluminum one... the only thing i will have to do is mod the carb linkage since it is differnt then my 2 bbl ( where the cables and stuff hook up)
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Sweet! What would the aluminum intake have come from? I never heard of Ford making a stock aluminum intake for that engine.
I have the same intake, as does GMGT. I guess its very simmilar to the first edelbrock performer intakes for 289/302.
If your stock 2bbl linkage doesnt work for some reason you can get lokar cables. The throttle linkage might be fine but make damn sure your TV rod/cable is working correctly or you'll toast your AOD real fast.
My car had a TV rod and it was CFI, not too sure what carb cars had but its more that likely a rod. I tried attaching the old rod to the carb for kicks but I couldnt get it to be ajusted anywhere near correct and didnt want to risk it. So I got the lokar TV cable and never looked back.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
My carbed '89 has a TV rod. Dave, yours should have a rod and two cables (assuming you have cruise control, if not, then one cable).
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
It's a combination of factors. For one, if an engine is undercarbureted, it's running out of venturi area to suck in air. That pressure drop has to be made up, and it gets made up by more gas. More gas=fewer mpgs.
Also, the primaries in a 4 bbl are smaller than a 2 bbl, so if you don't floor it thru every stoplight, you'll pick up a little economy. If you DO floor it, well, hehehe...not so much.
