Cobra TC mod list
    Cobra TC mod list
    It's not long enough yet, lol
    '84 351w block
    Scat 4" stroke 4340 crank, neutral balance
    Scat 4340 H-beam rods
    SRP forged pistons (9.5:1 @ 64cc, .050 cut off the tops)
    Federal Mogul coated rod, and 3/4 groove coated main bearings
    Canton 5/8" steel main girdle
    ARP 460 ford main studs (to fit the girdle)
    Melling HP 10833 High Volume oil pump, ARP bolts
    ARP hardened oil pump shaft
    Canton 7qt oil pan, ARP bolts
    FRPP 1pc oil pan gasket
    TCI neutral balance flextplate, SFI certified
    ARP flexplate bolts
    Summit branded SFI balancer with removeable 28oz. balance weight
    ARP balancer bolt
    Cloyes Hex-a-just double roller timing set, ARP cam bolt
    Isky 280-mega hyd-flat-tappet 302 cam, 232º duration .517" lift 108º lobe center, adv. 3º
    Speed-pro HT-9000 lifters
    Trickflow 8.5" hardened pushrods, .080 thick walls
    RHS/Pro Topline 200cc 7/16" stud 58cc chamber heads, assembled with Comp Cams hardware, some bowl work and light cleanup
    Mr. Gasket Ultra Seal head gaskets
    Mac 1-5/8" 351w swap headers
    Mr. Gasket Ultra Seal header gaskets
    ARP header studs
    Scorpion 1.72 ratio rockers
    ARP head studs
    Edelbrock Vic Jr. intake, used, with some port matching and plenum cleanup
    ARP stainless intake bolts
    Fel-pro 1262 gasket
    Pro-Systems 750cfm Holley 4150 carb
    14x3" K&N filter w/ X-Stream lid
    MSD Pro-billet distributor, for use with a Vic. Jr intake
    MSD Digital 6 ignition box
    MSD TFI coil
    Accel Super Stock wires (for now)
    Autoilite 24's
    CSR billet alum. distributor hold down and fuel pump boss cover
    Stock tank with sump added
    -10an line to regulator, -8an to carb, dual-feed line
    Holley Red pump (for now, factory freak that outputs 10-11psi free flow)
    '89 Towncar AOD, Wide Ratio kit, Trans-go HP shift kit, A+ OD servo
    3-row radiator, add-on trans cooler
    180º thermostat
    3.55 Trak-lok rear (for now) w/ disc brake conversion
    Moog cargo coils, Gabriel Hijacker shocks
    '02 PI front brakes and springs
    KYB GR-2 police shocks
    17x8 oem '99 Cobra wheels w/ SVT center caps
    1" alum studded spacers
    255/45 and 275/40 Kumho Ecsta Supra 711 tires
    '86 Towncar alum hood w/ '78 z28 hood scoop
    '80 Town Coupé
    you got a new battery and power steering pump
    and dont forget to replace teh starter
      That's gonna be one BADASS Towncar!
      Do it with a 5spd!
        That's a damn nice list. Are you using the same 2.5" exhaust you were using before?
          Same exhaust as he had before. I actually really like the custom H pipe on that car. Its a very nice fit, somewhat better than the standard Mustang suff.
            pics????
              theres vids in the eagle has landed post mang
                Added the Custom off road H-pipe and 2400 stall converter done by local shops
                '80 Town Coupé
                  and custom wiring by gadget!
                    Is that junk done yet?
