Looks good mang. Here's a tip for next time, don't use cheap masking tape, like the kind made for packaging. It doesn't have a good enough adhesive backing to stick firmly to all the curves and shapes and will always lift back up in spots, causing what happened to you there. Use a masking tape which is made for paint masking. The green 3M automotive painters tape is the best you can buy, and will ensure that will never happen, but it gets a little expensive at $5 a roll. The Blue 3M tape which is made for masking off windows and trim when painting houses, will work as well, and is a little less expensive.
My Ma's 1986 Crown Victoria LX
I am definitely going to have to hunt down some good masking tape for next time. I also should mask the car during the day time and paint at night instead of doing everything in the dark with a couple of flashlights.
Future mods waiting in the attic. Most of this crap was intended to go into the '53, but that is on hold for a little while longer. I went to an automotive electrical service shop in Linden today and got a rebuilt 3g alternator for $165 for the CV core. I just have to figure out when I will install the alt. and e-fan.
nice goodies.~David~
Originally posted by packman View PostFuture mods waiting in the attic. Most of this crap was intended to go into the '53, but that is on hold for a little while longer. I went to an automotive electrical service shop in Linden today and got a rebuilt 3g alternator for $165 for the CV core. I just have to figure out when I will install the alt. and e-fan.
I was thinking of using the charge cable and fuse link from the audio system I had back in the day. It's in good condition and has a 200 amp fuse, but I think I might go with a new charge wire anyway because of its age.
The Little Things
Not much going on here. I added band style clamps at the end of the exhaust system to clean it up a bit. I got rid of the traditional exhaust clamp I used to hold up the exhaust. In its place is an aviation clamp. I think it looks a lot better.
Those are pretty clean looking clamps.~David~
The band clamps are really nice. I am going to try and polish them every time I clean the tips. Hopefully they'll stay shiny for a while. As of now, I'm planning a JY trip in Merryl Creek. If all goes well, I'll have older bumpers, a code E rear axle, LTD script tailights, and front & rear sway bars.
no wonder your always broke......buying the fancy clamps lol
Here are pics of the wagon sway bar installed, CAI, and the fender braces (mocked up; can't find our easy-outs). The steel cylinders on top of the intake are the spacers for the rear sway bar. They're cut down to size and need to be bored out.
Originally posted by packman View PostWhatever shade of blue that she wants. I might wait a little bit for the respray because I have a few trees that I want to get cut down B4 I do anything.Packman
Damn! I must have jinxed myself when I typed that. I shoulda been a bit more insistent with the folks about those trees; seeing what happened last March.
