If all you want to do is change the cam and intake, no machine work would be required. Just the usual cam-change gaskets, often available as a set (front cover, water pump, valve cover, intake manifold, and carburetor), and of course the cam and lifters. Additional parts that could be considered optional if you're on a tight budget but should probably be replaced on a high-mileage engine would include upgraded valvesprings (usually around $70) and a double-roller timing set (mine was $25 at AutoZone).
Correction from my above post: Crane's 364211 is actually a hydraulic roller. Let's see..... Edelbrock's regular Performer cam felt awfully good in torquelover's car, not a huge stump-puller, but it sure gathered speed in a humongous hurry .... Summit's K4400 cam and lifter kit appears to have identical specs for less money, about $100 for the whole kit (cam and lifters).
