Ooo freshly machined eye candy. Definitely an exciting part of a project.
1982 Ford LTD-S 351W Police Car
Originally posted by 87gtVIC View PostExciting. What color are you painting the block?
All main bearings check out, just got my ring and piston install tools, hopefully get the short block fully assembled soon. The FTI cam by Ed Curtis is on the slow train, I ordered it a month ago.
-Phil
Shiny old ford blue paint. Going to look great when complete.~David~
Looking good. What freeze plugs did you use? I had trouble getting the right depth.1990 Country Squire - under restoration
Thanks guys!
I had bought a set- but the machine shop installed their own. There's a part number on them EPC133B. Looks like they only sell them in bulk packs-Phil
Well the speedway springs didn't last too long! They no longer make the HD police springs- however the newer Aero springs are very very close. I got a set and cut 1 coil off of them (after 3 different cuts on the one side as an experiment. Technically the 1 side is 1 full coil, and the passenger is 1 1/8 coil, I think my frame is tweaked...
Ride height is perfect for me overall, has a 1" rake (26.75" to top of wheel well in front, and 27.75" in rear). If i were to do it again i might take 7/8 of a coil off, but im not complaining. Ride quality is WAY better, and I can't notice a difference in handling, although my massive sidewalls are holding me back in that respect. I did some calculations and my spring rate should be around 500Lb's/in, so a bit higher than stock HD springs. They pair nicely with the 200Lb rear springs and Bilstein shocks.
Also, the aftermarket Aero brake slider pins come with bolts that are to short (out of 3 different brands I've gotten). I had a loud clinking/rattle, one of the bolts stripped right out of the slider. I ordered a new slider and a pack of grade 10.9 flanged M8x1.25, 25mm long bolts (compared to 20mm). I figured it would be good to warn people, this was a bad thing for manufacturers to cheap out on, definitely could have caused an accident.-Phil
i had one of those bolts come out a bunch of years ago, not sure what hardware I used when I replaced it.
Most of these things seem to sit a bit crooked. I know mine has a slightly tweaked up frame but it had some lean even before that. I think it just happens after a long time, the ladder frames are not super rigid and the steady torque of the engine eventually tweaks it a bit.86 Lincoln Town Car (Galactica).
I was never a fan of the 925/175 speedway springs in my 2 door. for the same reason you mentioned; the noise going over bumps! In my opinion, they were waaaaaay too stiff, and honestly... entirely under damped with whatever cheap KYB shocks were on that thing. Good riddance. Paint on the engine looks excellent, too!**1976 Ford F-150 4WD: 360, 4 spd, 3.50s, factory A/C, 4" lift, Bilsteins, US Indy Mags, 35s Cruiser
Originally posted by P72Ford View PostI was never a fan of the 925/175 speedway springs in my 2 door. for the same reason you mentioned; the noise going over bumps! In my opinion, they were waaaaaay too stiff, and honestly... entirely under damped with whatever cheap KYB shocks were on that thing. Good riddance. Paint on the engine looks excellent, too!
Looks nice Phil. Car is LOW!~David~
Originally posted by 87gtVIC View PostFunny you mention under damped. When I met up with John and we picked up Phil he bounced the car and asked if my shocks were blown. They were KYB gas a justs...basically brand new. I may look into bilstein shocks. I am not swapping springs though. I feel they are fine....though do make a little noise in the rear over bumps...and maybe something coming from the left front when turning right over bumps. lol Other than that everything is great!
But with that being said, quality or not, if they are not rated to damp a 925 in/lb rate spring, then they won't. You want some AFCO 1020s or similar, matched to the high rate spring.**1976 Ford F-150 4WD: 360, 4 spd, 3.50s, factory A/C, 4" lift, Bilsteins, US Indy Mags, 35s Cruiser
Originally posted by P72Ford View PostBilsteins are a great product; I have 5100s on my Ram, and even with the lift and 36s the thing rides far better than stock. Plus... 5100s have a lifetime warranty.
But with that being said, quality or not, if they are not rated to damp a 925 in/lb rate spring, then they won't. You want some AFCO 1020s or similar, matched to the high rate spring.~David~
Phil. What type of bucket seats are you planning to get. I am excited so see what you come up with. It may nudge me to do similar.~David~
I do love my bilsteins, so fast to counteract bumps when cornering, the car doesn't skirt sideways a little when it hits one, it just keeps holding on around the corner. It's low, but for the most part it still has more ground clearance than most modern stock cars on my block! ha
So I've decided on the buckets- Jay (in NY) is supplying me with a pair of split bench sliders/brackets, and I'll fabricate an adapter plate. Here are the ones I've picked out: https://corbeau.com/sport-seat/
They look like they could have come with the car, while still appearing modern. I needed something that will be comfortable on my bad back, and be able to really hold me in on corners, as I get thrashed around with my bench seat. I called Corbeau and they are sending me out 2 vinyl color samples, one of the Spice, and one of the Tan, and I'll see what matches best. From other peoples pictures i think at least one will be pretty close to my oddball tan color. They come with a BUNCH of add on options, and i'm definitely getting the extra lumbar support. It will be nice to be able to recline the seat, as mine is fixed...I may even make the drivers side powered.
I'll also need a center console with.... CUP HOLDERS. A luxury to us box ownersLast edited by Brown_Muscle; 12-09-2020, 08:19 PM.-Phil
