any time the intake manifold is removed the oil MUST be changed........ask gadget what might happen
New Manifold!(again)
yeah there is a HO in my car for a reason other than performance. Something about an intake swap and a spun bearing the next day after not changing the oil.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostIn D, you should be able to get a downshift to second any any speed under about 50, but not above 55. If it won't kick down from D at 40, there is something wrong.
Originally posted by lincolnmania View Postany time the intake manifold is removed the oil MUST be changed........ask gadget what might happen
There is residual coolant in the manifold even if you drain it. Not much, but it doesn't take much if the motor is tired. I get away with it on my Chevy motors in the boat by draining the block. I can't get the block drains out of the 302, and it always dumps a little coolant down there. I could probably get away with it by removing the thermostat and using a vacuum to suck the bit of coolant out of the manifold, but I like to change oil whenever I have the motor opened anyway, just in case I introduce some dirt or whatever.86 Lincoln Town Car (Galactica).
Originally posted by MeLikeyStripperChicks View PostThain, all that depends on gears tho - I did a lil experiment last time I drove the Townie, I made a turn onto a loong straight empty street and floored it - spun in 1st, then hooked, got in 2nd, spun, hooked, and kept 2nd not to 65mph like I was saying before, but all the way to 75mph where I let off a bit and she immediately went into 3rd. I've had her on the freeway at like 60-65, put the pedal to the floor and she hits 2nd every time. This is with 3.08 gears.
I can take 2nd all the way to 70 no problem, with the slow revving 351 (4300 rpm shifts) and 2.73s. If I put it on the floor above 55, I get 2nd every time... Lower gears would obviously change that though.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by P72Ford View PostI can take 2nd all the way to 70 no problem, with the slow revving 351 (4300 rpm shifts) and 2.73s. If I put it on the floor above 55, I get 2nd every time... Lower gears would obviously change that though.2012 Mazda5 Touring | Finally working on the LTD again!
