Thanks. And as far as I know the club has been around since before I was born. The idea is the perp cannot steer the vehicle because of the long arms.
lol It gives the customer added peace of mind and security.
wait till the lock fails
There are also tools to break those clubs, although they are expensive. I watched a guy use one on a repossession one time.
Those switches and levers you removed look just like mine...
Maybe in the future I will change them.
Good progress, David. I am doing some underhood clean up, as well... except I took the engine out. I hope it'll be worth it when I get it back together.
I did pull the blower with the fender out, although I don't think you have to. It will make it a little easier, but not sure if it'd be worth the extra effort.
When I pull the booster, I may just replace it with a new smaller diameter unit.I may do away with the power brakes altogether in the future, though, so that part remains to be seen.
why in the name of all things good and holy would you install hydroboost in a vic?
Aggressive cam grinds don't provide near the vacuum that a stock grind does. Custom options can still provide a stockish idle, with excellent high rpm performance, but most aggressive OTS grinds do not provide adequate vacuum to operate power brakes.
Thus hydroboost, which cares not how much vacuum there is.
I do want to make my car a stick shift, in the future. I am undcided what I will do though. I considered eliminating power brakes all together, just to free up room on the firewall, perhaps for a clutch master cylinder.
there's a few cars at work (that come in regularly) that run hydroboost or aftermarket electric brake boosters because of the cams. It seems like an extra annoyance, but that's from teh perspective of someone who has to get the damn things to warm up and watches them getting repaired.
There is plenty of room for the clutch cable with the smaller brake booster so I would say that there is no reason to get rid of power brakes completely. I don't know how aggressive of a cam your going with but mine thumps pretty good and I haven't had any issues with loss of braking either.
1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
2006 P71, 1988 Bronco II, 1986 Baby LTD(5.0 & T5 swap in progress), 1976 16' Hobie Cat, 12' AquaFinn http://www.cardomain.com/ride/2651997UPDATED 20100826
One of my parts guys said that one of his TCs had hydroboost. He didn't know whether or not it came like that from the factory. Probably something installed by the first owner though.
