    It had a rubber backing on the magnets.
      I know how to do the job, its more of an annoyance.
      I wasn't actually telling you how to do the job, I was asking if it's possible to do it the way I described it. Since I've never had to do it I simply do not know.
      The one problem with those is people just assume they will protect the paint, which is true till they somehow get some metal flakes on them (sources for which are not hard to find in that line of work) - if said metal pieces are not noticed by the operator and wiped off accordingly the paint on the next tow job will pay the price.
        David, please post pictures of the top half of the bolt (the fracture area). This may provide a really good hint as to why it broke.
        Also, what brand are the bolts?
          They're ARPs
          Originally posted by SVT98t
            I was lead to believe they were arp bolts when the were purchased from trick flow yeas back. I then purchased the exact same part number and actual stamped arp bolts appeared in that package...you know the time I needed to replace the ones on the passenger side.
            I can post up a picture or two when I am back home. Bolt bore in the exact same manner and location just on opposite heads.
              Maybe they sent DERP bolts instead of ARP.
                DERP bolts..
                  Well we know that it wasn't David's fault, with his attention to detail.
                  Unless he was using an impact to install his head studs..
                    Things were done properly. Again, all of this stuff was originally installed onto the block while on an engine stand. No rushing was involved. I third the "DERP" bolts.
                      Trickflow seems to have issues with their tools and fasteners. I personally wouldn't trust anything from them other than the thick metal items (like heads). The valve spring compressor I got broke on the second valve. The OTC one, Scott probably still has.
                        I never understood why companies don't just stick to things they are known and respected for, and instead try to branch out into other areas that are already occupied with good products from other manufacturers - the only way to do this competitively is for the newcomer to either have some super-awesome product that is light years ahead of everything else currently on the market (not very easy to pull off), or to keep their prices low (which can only happen if either a new manufacturing method is employed, or quality is kept sub-par, or profits are being sacrificed). Only so many manufacturing methods out there, and we all know how greedy larger business entities can get, so yeah, that leaves pretty much one scenario - basically fuck the consumer. Too bad David here had to pay the price for this BS practice.
                          It sucks but now I know not to mess around with an engine build. go with actual ARP stamped bolts or nothing.
                          Ugha. I gotta use bolts so ARP it is!
                            Progress report:
                            No progress.
                              Same here. When it's nice out; I'm stuck at work. WHen the weekend finally arrives, it's either freezing or snowing or sumtin.
                                Progress report:
                                No progress.
                                Lack of news is good news of itself. Sure beats the one step forward two steps back that happens all too often with big jobs.
