Dave I was wondering if you ever thought of LED taillights ?
Originally posted by marquis_82_withneons View Postthat brackets made a world of difference. it looks so much more sturdy. and still fits by the booster. thats an aero body master and booster, correct?
Originally posted by mitymerc View PostDoes the firewall flex at all?
Originally posted by jaywish View PostDave I was wondering if you ever thought of LED taillights ?~David~
Thanks...One other thing I added was an 86 only? at least 86 and down MAP sensor bracket. I sandblasted and powdercoated it in matching powder to some of my other engine bay bits...barely see it with the harness running above it. lol
This style bracket has the MAP sensor sitting straight up. The newer style brackets have the sensor laying on its back like it is asleep.~David~
Do you have a CHMSL? If so I believe everything will be fine e.g. working cruise control. There is the possible exception of needing a different flasher for 4-ways, though I think you will be OK without.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
cruise gets dumb with all LED tails. If you keep normal bulbs in the center lamp it will work. I run all stock lamps because of the flasher thing. the electronic ones don't make the proper noise. I actually rolled flashers in the Conti to get a mix of the right flash rate and the right sound.86 Lincoln Town Car (Galactica).
Originally posted by jaywish View PostDo you have a CHMSL? If so I believe everything will be fine e.g. working cruise control. There is the possible exception of needing a different flasher for 4-ways, though I think you will be OK without.
Originally posted by gadget73 View Postcruise gets dumb with all LED tails. If you keep normal bulbs in the center lamp it will work. I run all stock lamps because of the flasher thing. the electronic ones don't make the proper noise. I actually rolled flashers in the Conti to get a mix of the right flash rate and the right sound.~David~
Originally posted by 87gtVIC View PostThanks...One other thing I added was an 86 only? at least 86 and down MAP sensor bracket. I sandblasted and powdercoated it in matching powder to some of my other engine bay bits...barely see it with the harness running above it. lol
No flex. If anything is moving it is the cable in relation to the adjuster.
Bummed as my air compressor took a crap the day this all went together. I had planned to powdercoat the bracket....I left it bare steel in where it was ground down. It was ground down as I filled in holes I had previously tapped but then welded back up.~David~
Stock 87 and up bracket. You 86guys have it on the passengers side fender.~David~
need to drill holes in the upper AC bracket to mount it. Pretty sure 86 brackets have no hole there.86 Lincoln Town Car (Galactica).
