are those big magnaflow tips you got gonna stick out before the wheels?
Thanks guys.
Naw. My dad bent up some 90's in 2.5" pipe. Just have to flare the pipe end to 2.5 ID so it slips over the muffler and I will have them turned down and angled a little bit towards the sides of the car.
In time I will have the mufflers back bent up for me and the magnaflow tips will stick out underneath the rear bumper.~David~
I had mine dumped for awhile but I grew very tired of the resonance inside the car. Made me feel like I was inside a speaker.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
May make me get tailpipes bent up sooner than later then.
I have a bumping stereo so maybe that will offset some of the resonance? I want this car to sound obnoxious. I want it to be seen and appreciated.~David~
Got my new end links and bushings. The bushings for the sway bar have no slit in it to slip over the bar.....so I guess you make a slit or take the end link off and slide it over??~David~
gotta slide it on. You get poly's or rubber?-Phil
Originally posted by Brown_Muscle View Postgotta slide it on. You get poly's or rubber?
Originally posted by Pirate View PostDid you get taller tires for the Bullitt wheels?~David~
You will be fine cutting a slit in the flat side of the bushing. All of the aftermarket sway bars I ever installed had that slit in the bushing.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Yeah I mentioned that to my dad...he suggested it was better to slide it over though. Endlinks will be removed anyway so it does not really make a difference. But that will be the last resort move. These wont go on until I have my springs and shocks to install though.~David~
I liked the brown tag bucket.
I guess I'm just a monochromatic kind of guy.
The car is looking great David, and I can only imagine it when its cut and buffed. The color is great, and with the drop you have planned... it should be really, really hot.**1976 Ford F-150 4WD: 360, 4 spd, 3.50s, factory A/C, 4" lift, Bilsteins, US Indy Mags, 35s Cruiser
Thanks Nate. I always noticed your were kinda boring. j/k
I do like the paint matched one as well...but I have a problem with grabbing hard to find parts. I cannot stop it.~David~
Over a year ago I purchased an entire set of General Grabber UHP's 255 50 17's. With the drop, and these taller tires I hope I dont trash my fenders.
Well in the short time I had them they have done great. I only had them on for maybe three months collectively, as this summer I ran my winter tires year round. The tread pattern is just manly looking and I felt the handling was just as good as it was with my previous 245/45/17 Goodyears. It is just a ballsy all round tire. For the 500 I paid for them I cannot complain in the short while I used them. They will go back on the car next year after winter has passed and stay on through the good seasons. Then I will be able to give you a full report...but by that time you may have already purchased some new tires.~David~
Just went and unpacked the halo headrests I painted up a couple months back. Well they didnt fare to well as whatever cracks were there before paint have no amplified.
Whatev's I have matching headrest covers (match to the seat covers) that fit the exact contour of the halo..minus the hole in the middle. Was just a little downer.
