I was going to do it on saturday, but then I remembered I had a track meet...they should get done this week.
I got bored today after track practice, so I decided to throw in the analog clock, and all the blue LED's in the speedometer, clock, and HVAC controls. I'll post pictures whenever my camera decides to work.
Going to sandblast it tonight, might get it primed as well.
I'll get pics of the lighting set up and post them up when it gets dark.
I also pulled apart the clears again. I'm going to just swap the backs with the current ones I have installed, and do the insides with chrome paint. They are just too rare.
I repainted the clears in silver instead of black.....
IMO they look better this way.....
hey just wanted you to know don't bother with a mustang AOD they are the weakest, just build your crownvic trans, or find a crown vic squad trans
I'm assuming you saw my transmission thread lol. Thanks for the tip, I was kinda curious about the mustang trannies. I talked to silverfox on click click racing, and he will hook me up with one of his valve bodies and a 5k governer when I need it, and advised me to get a 3k stall converter. He also said to use an 89-up aod out of another panther.
no updates yet, wheels have yet to arrive, and I have 200 dollars of front end pieces just laying around in my room. Although I did come with the fangaled idea of putting a 351 in it eventually.
I just reread through the thread and realized that I never posted the results of the headlight relay.
10 volts to the lights before the relay
14 after :headbang:
Thanks again Dave!
HID's here I come! (after I get the money lol)
94 351 Roller Block
TFS Intake (if it fits, going to measure in person, but if it is 11.5 inches, it will fit)
Comp XE258HR Cam
1.6 RR's
AFR 185 heads 58cc Combustion Chambers
70mm Throttle Body/EGR
24 lb/hr Injectors
Haven't decided on converter yet
SilverFox Valvebody
Mustang Governer
3.73 Trac Loc Rear end
I'll worry about a torque converter when the time comes, but this is what I'm going with. A few more things that I plan on doing aesthetic-wise, and then I can go motor shopping!
