Ok, so for this winter, Im leaving the hubcaps and that on, but for next winter, I thought of something else. After I get the new wheels, Ill probably sand plast and paint the current ones gloss black (not before making sure that I get some tire smoking use in with these before they croak) and put the explorer center caps in. Not sure how it would look, but it sounds cool. I also compiled a list of everything I want accomplished on this thing (I was bored in study hall), Ill post it up when I get the ambition lol
"Vicky"-1987 Ford LTD Crown Victoria
Last edited by hemihotrod402; 09-28-2009, 08:48 PM.Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
New Project: Vicky II - 1981 Ford LTD: 61,XXX miles, virtually rust free. Currently For Sale
Ok Finally got the List. This is my long term goal for the car, and the sad thing is, by the time I get done with it, Ill probably want to restore it. Im swapping out the engine and trans just because everything is numbers matching and I do NOT want to blow it up.
MAJOR PRIORITIES!!!
79 Landau Grille Blacked Out (Wednesday maybe?)
Headlight Bezels Blacked Out
140 MPH Speedometer
Blue LEDs for Speedometer
Rebuilt Exhaust System
Coys C-5 Polished Aluminum Wheels 17”
255/45-17 Tires
Engine
87-93 Mustang HO Engine
Engine bored to 306
306 ci Pistons
Aluminum Cylinder Heads
Comp Cams Box Upper Manifold
Vortech 87-93 Turbo Kit
Ford Racing Cam
1.7” Rocker Arms
Aluminum Radiator
Electric Fan
3G Alternator
MSD Distributor
Ford Racing Plug Wires
Drivetrain
87-93 Mustang AOD Transmission
Full Rebuild Including Clutch , Torque Coverter, etc.
3.27 Rear Gears
Aluminum Driveshaft
Suspension
95-02 Front Brakes (Control Arms, Spindles etc.)
95-02 Rear Brakes
All necessary Equipment to do Brake Swap
Wilwood Universal Brake Calipers x4
Cross-Drilled Brake Rotors x4
PI or Wagon Front Sway Bar
Wagon Frame Braces
2” Drop Springs With 25% better Spring rate (after wheels)
Interior
Replacement Carpet
Jegs Racing Seats (Re-upholstered to match interior)
Embroidered Floor Mats
Glowshift Water Temperature Guage
Glowshift Voltometer
Glowshift Tachometer
Glowshift Oil Pressure Gauge
Rebuild Dorr Panels
Billet Specialties Steering Wheel
Replacment Cruise Control Buttons
Replacement Dash Pad
Shifter, windsheild Wiper, turn signal replacements
Sony Head Unit
Infinity Kappa 3.5” speakers
Infinty Kappa 6.5’ Speakers
Infinity Kappa 6x9” Speakers
Exterior
Clear Turn Signal Lenses
Replacement Vinyl Top
All rust redone
Repaint
Aluminum Rear Window Trim
Exhaust
Ceramic Coated Headers
Custom Bent 2.5” Exhaust (no cats)
Flowmaster Super 44s
Im not going to Price evrything, just because I would have a heart attack, but it is well north of 15 grand
Heres the tally so far
Steering Wheel Cover: $15
79 tailights; $10
Ford Racing Valve Covers: $181
JVC Head Unit: $64
Pinoneer 6x9 rear speakers: $56
Insignia Door Speakers: $8
Urethane Swaybar bushings and Links: $30
PI Rear Swaybar: $60
APC Universal Intake: $50
Total $474Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
Sounds good. Takes time..but one by one you will surely cross of that list and have a wicked ride.~David~
well after next year, sadly this will prolly be pushed to the back burner, cause I got college to pay for lol. But I truly hope to get it done.Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
Originally posted by 86VickyLX View PostCollege sucks, it just takes money that should be put towards other stuffBut on the other hand, then you can make more money after you graduate, and buy even better stuff!
and 4 the record, I CAN ACCESS THE FORUMS FROM SCHOOL!!!!!!!!!:evil:
ALSO POST #100!!!Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
College admissions propeganda must look a lot different these days. 10-12 years ago, everyone was still insisting that you could study whatever you pleased, and then get a job when you got out because you had a degree. Boy had that changed by the time I graduated ....Last edited by 1987cp; 10-01-2009, 09:11 AM.2012 Mazda5 Touring | Finally working on the LTD again!
Enough of this college bullshit...back to his car and the awesome work that will be done.~David~
Originally posted by 87gtVIC View PostEnough of this college bullshit...back to his car and the awesome work that will be done.Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
ok, so the exhaust went out on me tonight after the football game. Its behind the cats because its not loud enough. Its either the Y-Pipe or the muffler. Either way though IT FUCKING ROCKS!!!!!!!! :headbang:
Also, just to see how loud it is, I left a couple lines of rubber coming out from behind the parking lot. Probably caught that on camera but oh well. Defiantly turned a few heads though.
Pls its the perfect excuse to get dual exhaust with mustang headers, catless H-Pipe, and Louder mufflers. Tonight rocked (even though we lost 48-0)Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
fixed the exhaust today. Just replaced the tailpipe and put on a Thrush turbo muffler. I hope its just not broken in, because it made no difference whatsoever. That Mustang Catless H-Pipe is still on my christmas list. I wish we would have just pulled the muffler and ran open exhaust from the Y-Pipe, that sounded so coolParts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
Yea man I had a Turbo muffler on my Vic and it almost sounded quiter than stock, but it got a little louder after it broke in. I got sick of it being so quite so I ripped it off and just recently bolted on a Summit Chambered Race Muffler. It is still not wicked loud, but it has a noticible rumble. Vid below of it.
http://www.youtube.com/watch?v=v6Pfv-Cd0kc
If you looking for louder with cats, try some 40 series Flowmasters.Last edited by 87DeuceVic; 10-04-2009, 04:29 PM.-2004 Crown Victoria Police Interceptor - Daily Driver - 17" Bullitt's, 235/55/17 Goodyear Eagles, Ex-NH State Police, best 1/4 mile time; 15.3 @ 90 mph
-1987 Crown Victoria 2-Door - Project - 90k miles, Summit chambered muffler, Sunpro gauges, parked since 2010, fate tbd
well, I calculated my list cost. I was waaaaaaay off with my estimate of 15 grand. Needless to say, I could buy a 2010 Mustang and gas for that mustang for 3 months with the amount of money that list would set me back. Im working on setting my sights lower.Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
no need to downgrade your list, just lengthen the time estimate.
thanks for the advice. I think I may have what my approach is going to be with this car.Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
