1990 country squire resto/lowrider in UK
    I would personally bitch slap any man that said 90-91 dash removal was easy.
      True that!! LOL
      '88' MGM wagon (mine and my sons toy)
      "60" chrysler New Yorker (my project)
      "78" Chevy 1 Ton P/U (yard horse)
      "01" Ford Explorer (wifes DD)
      "93" Chevy Suburban (my DD)
        Heater Core replacement time!!
          Just my thoughts also. Got one waiting to go in!
          Andy.
          www.lowcamaro.com
            dropping the dash to get at the air plenum for a core replacement isn't that bad... REMOVING the dash... that's an EPIC PITA!
              figured while he already had the dash out.......
                Finally got the dash clear
                Took me 1 hour to try to remove the wiring plug from the fan resistor pack on the firewall behind the plenum. Eventually gave up and had to spend another hour trying to undo the 2 8mm bolts holding it on. Here's the little sucker
                Even then it took some pulling and levering to get the plug off. This is why
                You can just see the rust on the pins. These are going to need a good clean up.
                I said earlier that dash removal on this 1990 cv was a PITA, but I was wrong. PITA is a complete understatement. This could be a new punishment for criminals. Rather than going to jail they have to remove the dashboard on a box panther.
                I'm seriously looking forward to putting this back
                But it wont be going back like this - many mods will be done including removing some of the wires and possible rearrangement. More of that later. Now I can get back to the welding.
                Andy.
                www.lowcamaro.com
                  damn thats bad!!!!!!
                    not near as bad as the one in my 88 was right after I bought it...
                      slymer: Now THOSE are some scary pics.
                      '79 Continental Town Car
                      '90 Crown Victoria LTD
                      '94 Crown Victoria
                        ah, melty blower resistor plugs. I've never unplugged mine. I tried once, and it would not let go. I expect its fused together. It works, so I'm not dicking with it.
                          yeah... that was the only reason I replaced mine... it no worky.
                            Here's the last state of play with a little flange left over and took advice from rellik god and removed the last bit.
                            Out that comes with rust underneath. Here it is cleaned up
                            Heavy rust to come out next
                            Oops! Cut through the plate below it, so have to weld it up
                            New panel fabricated and offered up
                            and welded in
                            I'll put the other 2 layers back tomorrow.
                            While i was removing the air bag safing sensor from the bottom of the A post, I spotted this
                            and this
                            Sort that out next.
                            Andy.
                            www.lowcamaro.com
                              vigilance!
                                Ooops! Missed a photo out above! Should have said....
                                Sort this rust spot out soon
                                Todays jobs were easy for a change.
                                Remove all remaining rust..
                                Fabricate a plate to get the top of the A post back to 3 thicknesses..
                                Drill some holes in it to be able to spot weld through
                                Mark where these holes will be on the A post, mask them off and etch prime the post and the back of the plate so it'll never rust again!!
                                You can just see the small masking tape patches if you look closely!
                                Weld it in tomorrow and fabricate the final closing off patch.
                                Andy.
                                www.lowcamaro.com
