Originally posted by Piece-it pete
View Post
Sly's Panthers
ok... holes drilled and on the vic. Thanks again Ford for the sagging ass aero bumpers... still can see the web address though.
Leave a comment:
swag
I got the license plate bracket too... but since it doesn't have bottom bolt holes... gonna have to drill baby drill. It's going on the vic.
Leave a comment:
Certainly looks like it. I was able to reuse them on my 89 MGM way back when as well.
Leave a comment:
Nice!
Are those your stock 'rubber bands' holding your rear speakers in?
Pete
Leave a comment:
always thought that was a bit of a sketchy design. Seems like it should have had a more powerful shock, or two weaker ones or something all along. I think Ford gave up on them after 82 or 83. The hoods retained the gas shocks but they seem to work on the hood for the most part.
Leave a comment:
I always wondered about the geometry. Because years ago, I replaced mine with new ones and it still would not stay up.
Leave a comment:
finally got the trunk to stay up on the Mark. seems the geometry on the lifts needs some adjustment... like the stock location is totally wrong. I made a temp-perm fix and will look at getting a mount point located on the wheel well, which would be better for the mechanical advantage.
The brackets are made of some punched angle steel. I folded it over to give it better rigidity (2 layers are better than one).
pics...
it even holds itself up at lower points too
I'll probably use a universal eyelet style bracket like this one: http://www.autopartsbylou.com/lift-s...item=to-brk285
Leave a comment:
Originally posted by 87gtVIC View PostWait the old plaque they just taped over!? lol
Make sure to apply a dab of silicone to that intake casting plug to ensure it stays put.
Originally posted by jaywish View PostHi,
Is that a whole HO motor in there? With the aluminum valve covers? I ask as the last time I tried to fit a casting plug it interfered with the oil fill cap.
Jay
Leave a comment:
Hi,
Jay
Leave a comment:
Leave a comment:
