Sly's Panthers
Nice. Does that gauge use a shunt? or is it taking the entire current hitting your amplifier? Or am I confused in the workings of an amp gauge?~David~
if it has a shunt, it's internal. The power goes in one side and comes out the other. I would imagine that it's a inductance style ammeter internally (a coil around the power bar creates a voltage that is compared to a reference for a +/- reading and displayed accordingly.
New 12V outlet on the right. For the first time since I've had my dash cam, I can see my gauges easily while driving. This will be nice.
My wagon has a similar squeak. Naturally, because old car, people right away assume something is terribly wrong. Go beater!
Originally posted by chitownvic View PostBeater gunna Beat! Love it! That damn idler pulley squeak! My 90 never shut up!
My 89 MGM sounded the same way the entire time I owned it. Oddly the 89 LTC was silent.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Modified the Automatic Climate Control in the Mad Marquis today. Added a switch to control the vent door. The switch controls a vacuum solenoid that controls the vacuum actuator for the vent door. I had to cut 2 vacuum lines under the dash to totally re-route the vacuum and plug the lines to the HVAC controls. The black/white that goes to the actuator and the black/blue that comes from the solenoid and then link those together under the dash. It works like a champ.
The under hood rig:
the black vacuum line is vacuum source. The black/blue line is the thermal blower lockout vacuum control line.
The red wire is to power and the green wire goes to my switch, then to ground on a bolt under the dash.
demo vid:
What is the actual purpose or benefit? I am just not following.~David~
I have control over when and where I get vent or not. I can force MAX/AC on this system now.
