so I re-wrangled my fan control wiring and added a couple of diodes so that everything triggers low but only high temp triggers high instead of everything triggering high (I have a soft start on the high trigger so it will trigger low first and then high 5 seconds later).
so yeah... the rats nest in the Cake is getting worse. Also, GM diodes because Ford's don't have in-line blades to fit in-line fuse holders.
