Battle Wagon is still going strong. Took the snow's off the other day and put the blacked out HPP's on. Also, stock HPP center caps fit fine with a little help from the die grinder.
There's a silly metal ring inside the cap you need to grind down flush with the sides, and then just carefully take a little material off all the way around, and hammer the dust caps on the rotors flat. Then HPP center caps fit fine on the stock brakes.
16.3 out of a lopo is pretty damn decent honestly. It must still be fairly healthy. I've seen really tired lopos run steady low 18 second quarters before.
It's hard to believe that car is a winter beater. It's in a lot better shape than my CV. Seeing the Battle Wagon in person makes me appreciate how clean and sound that car really is. Nice work!!! I loved the '69 Z28 that couldn't start up in the waiting lanes. LOL
Battle wagon looking good, be careful don't make it too nice!
2022 Ram 1500 4x4 5.7 Etorque, Built to Serve Edition, (Granite Crystal / Black) Past Panthers
Thanks guys! Time slips and a video for you! (Too bad the Marauder was so loud)
The only thing I've done from the last time I raced it (and ran two 16.7's) was add a B&M shift kit, and throw those HPP's on.
I also rolled 247K on the way back and still got 20mpg driving through NJ and PA.
